- Joined
- May 10, 2024
- Messages
- 1,313
This is a literal build from hell, I would put the difficulty a 10 out of 10.
I put flock and once it dries, some places didn't stick so either you try to do patches but it shows or wipe it off off but the lacquer thinner will melt the plastic. It'll take anywhere from 3-6 touch ups. On the door cards for exemple since it has two alcantara color I've been on it on and off for 2 weeks. The paint creeps under the masking tape and melts the plastic, I had to sand the plastic and do more touch ups.
I had to redo the flock on steering wheel 4x! I practised a while with different techniques to emulate stitching the perimeter of the screen. I ended up using a toothpick dabbing the paint on an scrap piece 5-6 dots before the correct amount of paint was left on the tooth pick so it could be applied to the model.
Each light switch is painted and each has their individual decal, microscopic decals! They are so small I use jewelers visor which I think is 10x magnification to be able to see what I'm doing. Then a day later you have to apply a varnish on the decals so they don't fall off in a couple years.
